- Jayco-noslideExplorerI feel I need to winterize when temps will fall into the 20's for more than a couple of hours. But, if I were heading south in a week or so I would probably leave the furnace on lowest setting or run an electric heater on a low setting.
- maillemakerExplorer
I use the blow out method every year and only use 3/4 gal. of pink stuff in the traps. You have to protect the traps because they don't get blown out.
Yup, me too. I don't put the antifreeze in the system lines.
Steve - bsinmichExplorerI use the blow out method every year and only use 3/4 gal. of pink stuff in the traps. You have to protect the traps because they don't get blown out.
Thanks for all of your kind suggestions. I decided to take on the learning curve of winterizing it myself. The worst part being locating the required drains. I also had a difficult time finding a blow-out fitting, so I found a short piece of hose and installed a male air hose coupling on the other end. This worked well, so I am good to go.
Thanks again for sharing your knowledge. I look forward to learning more.
You may find the blow-out unnecessary.
On my 1990 Winnebago Warrior, once I pop the drains (there are 4 of them!) and open the faucets inside to prevent a vacuum, the system drains completely without the need to blow-out. I bought the blow-out fitting and tried it but nothing came out but air.
Steve - wbwoodExplorer
Went to investigate our new class c for the by pass valve and pump to prepare it for winterizing. What a PITA to get to. I thought a more expensive and nicer rig would make it easier, NOT! I decided I will just go ahead and pay to have it done and use CW's $10 winterizing coupon. - radar_indyExplorerThanks for all of your kind suggestions. I decided to take on the learning curve of winterizing it myself. The worst part being locating the required drains. I also had a difficult time finding a blow-out fitting, so I found a short piece of hose and installed a male air hose coupling on the other end. This worked well, so I am good to go.
Thanks again for sharing your knowledge. I look forward to learning more. - Gene_in_NEExplorer III
rockhillmanor wrote:
Lesser expense would be to purchase some "Wag-Bags".
...When traveling from the midwest south most CG's are closed Oct 1, until you hit the real southern states BUT there ARE some CG's that stay open....I purchased a thetford porta pottie for the trip down with a winterized RV. For if nature called while on the road between CG's I did "NOT" have to use a public toilet!!.... - Coalminer_UGExplorer
Vulcaneer wrote:
radar_indy wrote:
Just trying to be safe. Advice will be appreciated.
If you want to be safe, and want advice, just take 20 minutes and invest $12.00 and winterize it. Peace of mind.
x2 - rockhillmanorExplorer II
wbwood wrote:
..but that doesn't mean we won't use it. We just won't use the water inside. Many people often think they can't use their RV after they winterize it. You can if you will be at a location with a bath house....
Ditto X2
When traveling from the midwest south most CG's are closed Oct 1, until you hit the real southern states BUT there ARE some CG's that stay open. Usually the ones you can see from the interstate. They just don't have water hookups.
Their bathrooms/showers/laundry are 'always' open.
Carry a few bottles of water for washing hands, etc. For all else use the CG bathrooms!
Part of my route from north to south had no CG's open. Not EVER wanting to use gas and/or rest area station toilets 'while on the road traveling' so.....
Looks and sits EXACTLY like the toilet in the RV. Has a removable cassette underneath that acts like a mini black tank. Placed it next to my RV toilet and when I reached a CG if I used it, the bottom comes off with a swivel pipe that you dump down the sewer hookup or a bathroom toilert. You don't see it or smell it. Real slick.
http://www.thetford.com/HOME/ApplicationHome/RecreationalApplication/tabid/85/Default.aspx
Depending on how much you think you might need it you can buy models with different size holding tanks! :B
Walmart used to sell them for around $60 bucks. I found it very useful. - mlts22Explorer IIIn Indiana, I wouldn't chance it, i'd go with the pink stuff. If one has access to enough power to run a heater, or just run the furnace at 40-50, then one can delay winterizing, but to be safe, it can't hurt just to winterize and not worry about it.
38,779 PostsLatest Activity: Jun 16, 2026
