brirene
Oct 20, 2013Explorer
Usually takes extended periods of hard freezing for pipes to freeze, so if you're getting into the high 40's or above during the day you're *probably* ok. To be safe, you could drain the water heater and open low point drains. I would probably just run heat on lowest setting and open cabinet doors. This assumes you have no exposed water lines. Just my $.02. Have a great trip.
38,779 PostsLatest Activity: Jun 16, 2026
