rjstractor wrote:
garyhaupt wrote:
The only place I haven't had the guts to go to...the beaches of Oregon or Washington.
I'm curious as to why. If you stay out of the surf and the soft sand above the high tide line you could probably run around in 2WD without an issue if you lower your tire pressures. I've seen lots of RVs on the beach in Ocean Shores and Long Beach. Sometimes they get stuck but it's usually the ones who go where they know they shouldn't.
If I was with another heavy vehicle I would go. But that area is no place to discover where a soft spot is. I would not want to be sitting out there looking at the tide coming in. I carry a VIAR compressor so can air down and up. However..only a fool would go out where they can loose their rig on the hopes that everything will be okay. I have seen lots of pick-ups n campers and vans out on the beach..and a couple tow truck on dualies..but never an C or A.
Gary
