Mr.Mark wrote:
Mr. Bob, I would think that if you want it truly off, you need to flip the breakers for it. I assume that when you say 'switches' that you are just talking about the 'on/off' switches.
I have a tankless water heater for our shower, I have to turn the breaker off for it not to heat. We also have an electric hot water tank that us sufficient for us if I need to watch electric power. The 'tankless' will pull some amps.
Safe travels,
MM.
I had had that thought, in fact that is how I had solved it so far. Just wanted to make sure there wasn't something else I was supposed to be doing.
