dougrainer wrote:
bobkatmsu wrote:
Does not have a furnace! I hadn't even looked for it yet as it hasn't been an issue living in Florida. Used the heat pump a few times and that worked fine. Do not know if it had hot water heater. Newgle is telling me it could have been made with a 10 gal hot water heater or the Oasis system.
If NO furnace, it came with the Oasis system. At sometime he must have frozen the Oasis and replaced it with the Precision Temp system. When you freeze a Hydronic system, you have destroyed it and will need replaced. The Precision and Oasis will utilize the same hook ups. The only difference will be how the system is controlled from inside the RV. If you had a Hot Water Heater, Sorry, no such thing. If you had a (cold):W WATER Heater, then you would have a HOLE in the side of the RV, usually on the drivers side in a DSDP. Hole about 15 to 18 inches square. As I stated, The Precision temp website is horrible as it does NOT show operation or the remote wall switch. If the website DOES show it, it is very difficult to find it. Doug
Nothing like that on either side of motor home.
