bobkatmsu's avatar
bobkatmsu
How do I have hot water?
I have a new to me, 2010 Newmar Dutch Star 4369. It comes with an on-demand tankless water heater. It has been parked the past week, hooked up to a 30 amp service. I have had both the electrical and propane switches to the water heater turned off. Just for the heck of it I turned on the hot water at a faucet and got...hot water. How does that work?
  • 1. You need to post the BRAND and model number of the Heater. Newmar used Oasis for LP and 120 heating
    2. Did you start the chassis engine and run it at anytime before you checked the faucet? Oasis has a engine heat option and that will heat the tank if the engine has run long enough to get to operating temp. Doug
  • Mr. Bob, I would think that if you want it truly off, you need to flip the breakers for it. I assume that when you say 'switches' that you are just talking about the 'on/off' switches.
    I have a tankless water heater for our shower, I have to turn the breaker off for it not to heat. We also have an electric hot water tank that us sufficient for us if I need to watch electric power. The 'tankless' will pull some amps.
    Safe travels,
    MM.
