IAMICHABOD
Apr 25, 2018Explorer III
PenMan wrote:
I have the Truck System Technologies (TST) system. It has worked great. I had to add steel valve extensions (don't use the flexible ones) to get the sensors installed. I got them from Tire Man Valve Extensions but their webpage does not come up any longer. They are available from other vendors.
The best on the market,that are the original,are Tire Man Valve Extensions,This is his new website
Chuck is the original designer of these an he has been around for years. If you have any questions just give him a call, he is always happy to help. Any others are just cheap reproductions of the original.
The kit looks like This it is for all 6 wheels,they also come with flow-thru valve caps so you don't even need to take then off to check the pressure.
Here is a list of all the products he sells.
They are compatible with all Tire monitor systems.
