pianotuna
May 23, 2013Nomad III
Hi Harvard,
US gallons. Local fuel prices are as much as 5.266 per US gallon.
I do have air tabs--but all they seem to do is make the RV quieter (i.e. less wind noise). If I am traveling in the same direction as the wind I do get better mileage with the tabs. Against the wind it is still drinks fuel just as before.
I'll very shortly be going to larger tires. (215 R70 16 up to 235 R85 16) I'm hoping that will make a slight improvement. It will most certainly improve my lousy ground clearance. I did finally get a huge caster which I use in the oem hitch to "stop the grind".
38,782 PostsLatest Activity: Sep 10, 2026
