rgatijnet1
11 years agoExplorer III
If you look at the bulbs, you will see gaskets that are supposed to seal the headlight assembly. The bulbs run hot enough to burn you in a few seconds and will burn off the condensation if turned on for a few minutes. Drilling holes will just allow condensation to get in to an area that is supposed to be sealed. Check the gaskets on the bulb assembly and make sure that it is functioning and turn on your headlights from time to time, even during the daytime hours, and you shouldn't have any problems.
38,779 PostsLatest Activity: 6 days ago
