jsmart
Jun 16, 2015Explorer
most headlights have a hole in the rear where the bulb goes in, you can remove the bulb and check to see if the gasket designed to fit the bulb is intact, that's the most likely place moisture is getting in. As others have said here, drilling holes in the headlamp assembly will only let in more moisture.
