usersmanual
Sep 12, 2016Explorer
timmac wrote:
Both pics are the same trim, one is the lower part and the other is the higher part going up to roof area, so you say it just peels off, if so I can glue back up but I also don't want to damage the trim while removing.
sometimes the maker runs silicon or secoflex then its a mess taking off this trim.If its not sealed on either side then its easy
it just prys off as is a clip lip fit so to speak
just be carefull because you can stress crack the paint as this is painted rubber cover trim
looking at the pictures I don't see it as sealed so it should be easy to remove
