usersmanual
Sep 12, 2016Explorer
timmac wrote:usersmanual wrote:timmac wrote:
I have the weep hole covers, I know what you are talking about its a annoying squeak that has got worse over time, I have done all that I can from inside and I do believe the screws behind that trim are loose because the squeak comes from the exact same spot on other side of wall.
well pitter patter lets get at er its pretty simple to remove the moulding and take a look
Yea I can just get out a screw driver and pry away but what I am trying to learn is how to remove without damage.
:W
once you get the little clip off at the bottom then
you pry the moulding to pop it off the track to start then its just pulls off after that.it really very easy to do
its a aluminum track with a edge on each side and the plastic moulding clips over the edge on each side
Moulding link.1st one is the aluminum plate and second the plastic molding that clips over
http://www.prvparts.com/product-p/42948.htm
http://www.prvparts.com/product-p/100.htm
