rgatijnet1
Oct 07, 2014Explorer III
You can use a voltmeter to see if the voltage is present at the correct terminals but that WILL NOT tell you the amperage capacity at the outlet.
I would contact another electrician and have him inspect the wiring to insure that the correct gauge wire was used, for the distances run, and that the source is capable of supplying the necessary amperage for ALL outlets.
38,774 PostsLatest Activity: Apr 26, 2026
