TennTechMan
May 10, 2013Explorer
Dachristianman wrote:
There should be a drain valve somewhere close to the storage tank and pump. My Brave has a valve with a little ring on it that you pull up to drain the tank accessable through one of the rear storage compartments. That valve has to be pushed down in order to stop the water from draining out of that drain tube onto the ground.
Is this a different design valve from the 3 that are under the bed? Is it accessible from under the coach or inside the coach?
This sounds very promising.
38,766 PostsLatest Activity: Jan 10, 2026
