FIRE_UP
Aug 13, 2016Explorer
wolfe10 wrote:
You need to get your RIDE HEIGHT SPECS from your chassis maker.
Because of the very short driveshaft, as well as optimal shock travel, I would NOT, repeat NOT run out of spec.
And, with many DP's running the front ride height out of spec changes front end alignment!
So, your best bet is to verify that you are to spec, both front and rear.
Thanks Brett, I was hoping someone would tell the OP that there is some very specific specs in ride height requirements. You shouldn't just "jack it up" 'cause you want to. There will be consequences.
Scott
38,763 PostsLatest Activity: Dec 05, 2025
