FIRE_UP
Aug 06, 2016Explorer
brianseay1 wrote:
What do you all use to remove the watermarks from the sides of your rv? I have a black and gold finish on my coach and have the water runoff stains from the awning down the sides and can't seem to find anything to remove them. I have used the black stain/watermark remover stuff you can get at campingworld but it did not work. I have tried wax, wash and wax for airplanes and nothing has worked. Any help or info is greatly appreciated.
Sometimes water will pick up acid rain type deposits on top of your coach and, when trickling down, deposit them on the sides. And, that will leave almost the same type of hard water stain as you'd see with water that's not treated (water softener) out of a garden hose.
About 98% of most waxes are not strong enough or, I should say, do not have enough abrasiveness to remove those. In cases like that, an actual POLISHING COMPOUND is required. Three M makes all the products needed for accurately polishing paints. There are others but, 3M is what I'm familiar with.
I presently have both part A and part B of the 3M system. A is a machine liquid compound for rubbing out. B is the actual polishing compound which, is recommended with the use of a pro machine like the Dewalt that I have but, it can be applied by hand with very nice results. You may find that the only way baked on water spots will come off is with labor, and a compound of some sort. Your local auto parts store usually has different compounds too, along with all the waxes.
Scott
38,768 PostsLatest Activity: Jan 26, 2021
