rgatijnet1
Aug 01, 2014Explorer III
Just make sure that the "blobks" that you use are NOT concrete blocks. I prefer heavy duty jack stands, rated to hold the axle weight of the vehicle, as a minimum and make sure that the base of the jack stands is on a surface that can support the vehicle weight. Dirt or gravel is not a good surface to support a jack stand. The jack stand should be installed under the frame of the coach, not a body panel.
38,766 PostsLatest Activity: Jan 10, 2026
