mleekamp
Oct 19, 2020Explorer
typically, there is an ON/OFF switch for the step. Mine works this way, and you can test yours to see if it is the same:
Switch in ON position: step folds in/out as door opens/closes. All the time.
Switch in OFF Position: step folds out as door opens, remains out, until you turn ignition key to ON, then folds in.
Make sure you have the switch to OFF to keep it "out" while parked.
