DougE
Jan 03, 2015Explorer
After the first day you should be comfortable with your placement in the driving lane. You already know from pulling the trailer that you need to swing turns a little wide. You're sitting on top of the front wheels and the nose is a little shorter so you can swing the front end out a little further than you're used to doing. Probably the most difficult issue is dealing with fueling - lining up the fill point with the pump and having more space to pull away from the pumps before turning. Don't back with a toad! If you drop your toad and back into a campsite, throw out a cone or something to set where you want the back corner of the MH to be. All in all, not that big of a deal if you have trailer experience!
38,782 PostsLatest Activity: Sep 10, 2026
