BillMFl
Jan 04, 2015Explorer
I went from a 37 Ft Montana to a 38Ft MH. Two things: the drivers seat is just slightly behind the front wheels so if your butt is passed the corner you can start to turn pretty quickly and it helps to swing a little wide first if you can. Also, at first you will probably be way over to the right of the lane. Use both of your mirrors now and then to center yourself otherwise your wife will holler at you when you keep hitting the rumble strips! And until you get used to your rig try to always stay in a pull thru. I can back into a tight spot but I prefer not to. Especially after dark. And no quick lane changes! Those itsy bitsy cars can sneak up on ya.
38,782 PostsLatest Activity: Sep 10, 2026
