guardrail53
Sep 22, 2014Explorer
ET2 hit the nail on the head,, Keep the tanks full!!Put in a fuel conditioner and anti gel if you live in a cold climate, on the way home or to where you store it! Also run the generator on the way too, to make sure it gets the conditioner too! Check the air cleaner before you crank it up,, as that is a prime place for mice to nest! You do not want to suck a mouse or his nest into your motor! Also check and make sure none of the rubber hoses to the air to air have been chewed into! Mice will chew into anything!! If the exhaust is down low as with most DP, get a can of the same size, just a little bigger and slip it over the exhaust on the motor and the gen. Just do not forget to remove them before you fire it up!
38,783 PostsLatest Activity: Sep 22, 2026
