My_Roadtrek
Feb 23, 2015Explorer II
gerrym51 wrote:My Roadtrek wrote:
If you are storing it in the winter, depending on where you live, solar may not be very reliable. I would imagine Boston hasn't seen enough sun to charge much of anything.
Rodger-of course you are correct-i still intend to start up and RUN every 2 weeks.
I found some obd2 port solar panels. I will use it also.
since i found that promaster 21 day blurb in the manual i am more confident once every 2 weeks will be sufficient
thanks
Just keep in mind the colder the weather the faster the battery will discharge.
I also know Rt claims their solar panels will charge with no sun, what they don't say is how much. Probably not an issue in you situation.
Before I forget congratulations on the Zion.
38,782 PostsLatest Activity: Sep 10, 2026
