We are thinking about buying a class c mot or home (Ford e 450 gas burner) it's a 2013 with 110,000 miles on the drive train. Is that too many miles? What's your opinon.....thanks in advance
It got some use? Was it used as a second car? That's a lot for 5 years of use. Was it a rental? That said, if it's been serviced regularly and looks good, might be worth getting it checked out mechanically at least. You can test the coach systems yourself with a little help from someone, a friend, that has something similar.
