prolandsurveyor
Mar 14, 2018Explorer
How many is too many
We are thinking about buying a class c mot or home (Ford e 450 gas burner) it's a 2013 with 110,000 miles on the drive train. Is that too many miles? What's your opinon.....thanks in advance
Blutoyz wrote:
Get away from rental units and you will likely find the same rig for less money with about 30K on it....just my $.02 of course
klutchdust wrote:
Transmission and engine rebuild @ 100K?
Farmboy666 wrote:klutchdust wrote:
"I would not buy a gas motorhome with more than about 60k miles, or a diesel with more than about 110-120 k miles. "
These aren't your grandpas engines anymore. My gas engines have easily gone to 300K and diesel is even better. A diesel at 120 is about 1/4 of it's life. Big rigs go 500K and then get some rings and bearings. Ford's V-10 is a well engineered engine, i say that and I am not a fan of Ford products.
I agree.
VA-Apraisr wrote:
...V10 motor... At 100,000 on mine, just replaced the plugs/coil packs ($150) and every plug looked perfect...
prolandsurveyor wrote:
Thanks for the input' I think we are gonna pull the trigger on it .
ctilsie242 wrote:
SXSW is in town in Austin. What people are doing to their Cruise America or other rigs, especially after one too many... I really wouldn't want to use that rig unless it was hosed down with a good antiseptic and ran through an ozone machine.
At 100,000 miles, a Ford E-350/E-450 likely will need new hoses, new brakes, spark plugs and coils, a new heater core, fuel pump, air filter, oil filter, transmission rebuild, engine rebuild, alternator, shocks, tires, brake pads, and calipers. That's just the drivetrain. The RV part will likely need a ton of work as well, just due to all the twisting and vibrating that it has gone through.
This is all assuming there is no water damage, but almost certainly the cabover will be rotted to black goo unless really lucky.
Used ones from a reliable rental place like Cruise America that have a good reputation? Possibly. High milage ones from other sources, no.
