StingrayL82
May 06, 2018Explorer II
RvFNG76 wrote:
small block 360 2 bbl wanna go 4 bbl but havent nailed it down yet. The engine in this monster is untouched except for the egr being removed (plate slightly leaks) by previous owner. Another fun little deal now is speedometer jumps and goes nuts every once in awhile checked the gear in the tailshaft but it looks fine any ideas?
You can do what I did and hit up a junk yard for the 4BBL intake and carb. Any '79-newer Mopar with the 318 will have what you need, as the 360 heads were used on that engine.
As for the speedo, lube it. Graphite spray with the small red straw...unscrew both sides and shoot it down the ends. If that doesn't fix it, the problem is probably in your speedo unit.
