Dale.Traveling wrote:
Full tank, fuel additives as the owner thinks is best. Personally I don't use anything but with relatively mild winters my coach is only laid up from Thanksgiving thru mid March. Engine and generator are exercised regularly. Helps to have the coach in the driveway.
The conventional wisdom around here is that if you must run the engine, it's best to get it out on the road an bring oil temps up high enough to boil off any moisture. If you can't do that, it's best to not run it at all.
I do run the genny once a month over the winter making sure to put a load on it (ceramic heater works).
