Empty Nest, Soon wrote:
Setting up our first towed.
The hitch receiver on the coach is 20” off the ground. The attachment points on the car will be about 12”, a difference of about 8”, which is too much. I need a hitch receiver drop.
I read that the drop between the coach end and the towed attachment end should be between 0” and 4”.
Should I try to get the tow bars near level by buying an 8” drop, or aim for the middle of the target range with a 6” drop?
Thanks!
Wayne
if an 8" drop will get your toad level with the MH hitch then get an 8" drop. level is best. don't skimp.
