I have a Fleetwood Bounder 39R with Cummins 330hp Turbo diesel. Noticed that the Exhaust manifold was cracked and needs replacement. This is apparently a common problem with Cummins Engines. Ordered t...
Just had it done on my ISB a couple of days ago. Luckily Cummins picked up the tab minus a $100 deductible. It took the mechanic 2 solid days to complete. My coach has a DPF, so there was a little more in the way, but the Cummins service center said it would have been $1600-1800 for the job. They had to cut 3 or 4 bolts.
