I have a Fleetwood Bounder 39R with Cummins 330hp Turbo diesel. Noticed that the Exhaust manifold was cracked and needs replacement. This is apparently a common problem with Cummins Engines. Ordered t...
Glad you got the job done and saved some bucks,if a bolt breaks off in the block the easiest way to remove them is to hold a bigger nut over the broken bolt and MIG weld them together they come right out,the weld wont stick to the block because its cast iron
