Sir_Traveller
Feb 05, 2021Explorer
dodge guy wrote:
When plugged in the chassis battery does not get charged, only the house batteries. The converter/charger on an 03 is as basic as they come so it can very well over charge the house batteries after extended time plugged in if you don't routinely place a load on the batteries.
thank you... what is the best way to routinely place a load on the batteries? disconnecting the RV from the shore power for an hour every week ( for example) will get the job done? or should I disconnect it more or less often than that?
