pianotuna
Feb 05, 2021Nomad III
Sir Traveller wrote:pianotuna wrote:
Add solar, or charge once every 30 days while in storage.
When in use--make sure the converter is smart enough to drop to a float voltage. Overcharging is just as bad as undercharging.
I'll be moving to SiO2 batteries next summer as they can tolerate a LOT of abuse.
Get a tric-l-start for the chassis battery.
thank you
I have no access to the RV while in storage as I will be out of state ( I live in south California , so hot dry weather most of the year... if that is a factor )
There are timers that work over a seven day period. Or you could invest in a solar charging system, if the storage is outdoors.
