wannavolunteerF's avatar
Sep 08, 2013
how often to drive MH
I am debating whether to buy a MH or trailer for fulltiming. I constantly see the comment of "If you are a going to stay in place for a while, get a 5ver and if you are going to be moving frequently, get a MH."
Everything I have read/heard says you need to start or drive MH regularly, not leave it parked too long. So how often do you need to start/drive a MH when you are basically staying put?
I see myself staying for 2-3 months at time part of the year, and possibly moving/traveling weeks at a time between the times I park. I plan to volunteer park host in some state and national parks between travel times. I am leaning toward MH as by the time I retire, I hope to take DGD with me on trips and MH would be much easier to manage while traveling. Just haven't found a floorplan yet that I like as well as trailer floorplans for when I stay put. Trying to make a decision based on logical factors, not just "feelings".
  • We, too, volunteer for a couple months at a time and now we stay put in winter. We have a diesel and have had no problems with it. We do run the generator under load for an hour/month to 'exercise' it. However, we never just start up the motorhome and let it idle which is worse for it than letting it sit. You could take it out for a nice long drive at times but our experience is that no one does this if sitting for a period of time. I know fellow volunteers don't do this. We are very meticulous about keeping it well serviced when on the move. . . just our experience. Good luck with your choice.
  • If your generator is a diesel motor, why is it different from the other diesel motor you have?
    Barb
  • Barbara, the need to run the generator periodically has nothing to do with the motor whether diesel or gasoline. The issue is to reduce the effects of moisture, condensation, on windings,brushes, and contacts in the generator.
    JohnnyT
    JohnnyT
    With all due respect that makes no sense at all.
    Wet - Dry cycling is worse from a corrosion perspective than just letting an item sit wet. Drying it out lets chemicals that accelerate corrosion concentrate and corrosion to accelerate.
    Both generator and MH engine need to be run to recoat oil every where. But you need to run these long enough for both to get hot as wolfe pointed out previously.
  • My motorhome (Claas A) is parked at home for 5 months with off and on use. Then I drive it 1,355 miles to AZ. where it sits in one spot for 7 months!
  • DanTheRVMan wrote:
    JohnnyT
    JohnnyT is right on concerning the generator. Should be ran once a month at 50% load and the issue is to reduce the effects of moisture, condensation, on winding ,brushes, and contacts in the generator portion of the unit.
    The engines being ran, or not being ran, we can debate all day. Farmers are well known for not starting up diesels until they are needed, and that may be twice a year. I even know highway contractors who do not start certain diesel powered paving equipment all winter long. If you are going to start it, you have to take it out and run it to get it up to operating temperatures. For a diesel during the winter months that is at least 25 miles while under a load. Diesels are cold blooded animals and are difficult to warm up.
