dayakster
Apr 08, 2014Explorer
mtrumpet wrote:turbojimmy wrote:dayakster wrote:
Even when I'm plugged into the house I still have to switch my 12v on to get the interior lights to work
This doesn't seem right. The lights should work whether you're plugged in or not (assuming your batteries are in good shape). When you plug into the house (or run the generator), the 120V AC outlets and accessories (microwave, a/c, etc) should also work.
I'm assuming that she is referring to turning her batteries "on" from the battery disconnect switch. Which BTW dayakster, is not necessary to keep turning on and off unless you for example, would be going to put the coach in storage for awhile.
Thank you...I was turning the battery switch OFF to be safe but I guess I don't need everytime.
38,766 PostsLatest Activity: Jan 10, 2026
