BruceMc
Dec 30, 2016Explorer III
Here's a breakdown of the wall:
Where the tin is the inside lining underneath the coach. I cut a hole through the skirt to gain access to a gray water drain valve that the factory thought it was better to crawl under to access...
All framing in the last several years is welded square-wall aluminum, then as you see, expanded foam insulation (as compared to the brand Styrofoam, which is extruded foam) laminated with luan on both sides, then the fiberglass/plastic sheet. All is glued up, and is very rigid until water intrudes and separates the plys of the luan... arg! But the structure is still very strong.
I remember tin-sided rigs where all the framing was 2x2's and fiberglas insulation.... Yes, even earlier motorhomes were built using this construction technique! I think federal regulations stopped that practice sometime back in the 70's or 80's. I think.
Hope that helps!
Hope that helps!
38,769 PostsLatest Activity: Mar 31, 2026
