Lantley
Nov 05, 2022Nomad
Just because they did not originally have a connector does not mean you could not create a splice and add a connector just below the roof line.
If the roof is only filled with styrofoam you should be able to create a channel for the coax through the styro foam.
Maybe I'm missing something But running a new line across the roof does not seem like the most efficient way to reconnect the antenna.
