wa8yxm
Nov 07, 2022Explorer III
Usually on a Wineguard antenna there is a connector either right at or just under trhe roof (under a clamshell cover) and the damaged will be the barrel connector.. I wont tell you how bad mine was.. I cut the end off the coax (Both of 'em) Dressed the cables and applied new weather proof compression fittings. new barrel connector.. Strong signal.
