Vulcan_Rider
Aug 17, 2015Explorer
sh410 wrote:
A fully charged battery at rest 12.6V. The 13.5V you are seeing is a surface charge.
The full charge for a conventional battery at 80 F is 12.65 but for an AGM it typically is 12.8.
YOu can't use that 13.5 "surface charge" number for anything, except maybe to assure yourself that something is charging the battery.
An AGM at 12.5 is about 65-70% charged and might be "on the way out"
if that happened over a short period with a light load.
The other consideration, however, is that 13.5 is just a float voltage for an AGM. If the charging voltage never goes above that they might not be getting fully charged......ever.
You need to check that out before sinking a **** load of money into new batteries.
38,766 PostsLatest Activity: Jan 10, 2026
