harold1946
Aug 19, 2015Explorer
An amp hour rating of 200 is the same whether 6 or 12 volt.
Properly hooked up, series parallel, for each pair of 6 volt 225 AH batteries the usable AH is increased by each set. With each additional set the multiplier is 225.
With my example of 6 - 225 ah batteries the rating is 670 AH.
If it did not work this way anyone with 6 volt batteries would be limited to the rating of the two batteries. no sense in adding more.
The way it works.
A series connection will double the voltage, while maintaining the same capacity equal to the rating of the individual batteries.
A parallel connection will double the capacity while maintaining the same voltage.
A series/ parallel combination connection will double the voltage and double the capacity.
The way it works.
38,766 PostsLatest Activity: Jan 10, 2026
