FC
Feb 18, 2014Explorer
Our Georgetown has a manifold for hot and cold water lines in the wet bay and you can open the manifold to drain all the lines there. Since each line is home run its easier to drain, but I would be worried some water would stay in some low point between the wet bay and the fixture. I always blow out the lines when winterizing and then fill with antifreeze. The water holding tank has a relief valve at the end of the tank and this drains through a pipe through the floor at out the bottom.
I think the manifolds may have been installed only in the 2003 model year???
JM2CW
JM2CW
38,766 PostsLatest Activity: Jan 10, 2026
