gotsmart
Dec 05, 2020Explorer
For my 2004 E450 what solved the looseness in the steering was the replacement of the upper and lower ball joints, and replacing the OE steering damper with a Safe-T-Plus damper/centering device.
Changing the Ford OE damper to a Safe-T-Plus also made a big difference - because it is a damper and a centering device all in one.
Note: even with the above 2 changes I still feel the bow wave of passing trucks (passing me or from the opposite direction), but it is not death-grip-driving anymore.
I also had the OE front sway bar replaced and a rear trac bar (for flat towing) installed. I could probably add a rear sway bar - but it has not been bad enough for it, yet.
When replacing Ford ball joints, use a brand that has Zerk fittings on them. Ford likes to use permanently sealed ball joints. You want to be able to lube them.
I have posts about my chassis upgrades.
