Beverley_Ken
May 13, 2014Explorer
First and cheapest. Check you tire pressures, especially the front. At a minimum, go with the recommended inflation on the Winnebago label located near the drivers position, don't go with the maximum inflation stamped on the sidewall of the tire.
When our front tires are inflated to the side wall pressure (80psi for our c-class) we have the same handling problems that you describe. Putting pressure at the recommended pressure dramatically improved the handling.
Ideally you should weigh your vehicle and follow the Load and inflation table
Beverley and Ken
Beverley and Ken
