Ivylog
Sep 09, 2014Explorer III
I'm able to get 110 using the on board compressor. It helps to have a second person in the driver's seat watching the air pressure telling you when to stop airing and to apply the brakes to get the compressor to start pumping. When the pressure gets to 110 you start airing until it drops back to 110. Then applying the brakes several times to get the compressor to start pumping at high idle and usually two cycles will do it. Since it's the front tires and I have a chuck that stays on I do it by myself.
