dan-nickie
Sep 09, 2014Explorer
I run the diesel engine until I hear the pressure relief valve pop off.
At that point I know it has at lease 130 lbs pressure in the tanks.
Only then do I start airing up a tire.
YOu should be able to go from 104 to 110 within a couple minutes.
If the compressor kicks in again, stop and wait until the pressure builds up again.
BUT, have you weighed the rig to see how much air is needed in your tires? You very well may not need 110.
