donsuefuggrwe
Sep 09, 2014Explorer
NO, NO, NO, I assume you have a diesel engine. All you have to do is increase your engine RPM up around 1500 or so. Do this by turning on your cruise control and jog the speed control. Transmission in neutral of course. It will gradually increase engine RPM and raise the air pressure. 110 PSI no problem. 2011 National Tradewinds. I also assume you have quick disconnect fittings in your air line and a 50 foot air hose. Mine is in the fuse compartment next to and below the drivers seat. Good luck
