Canadian_Rainbi
Sep 09, 2014Explorer
It seems that a lot of responders don't seem to realise that you are filling from the DP's own compressor.
The on board compressor won't kick in until it's tank pressure drops to about 90 psi so if you get to say 100 psi in the tires and the tank pressure drops to that it won't fill any more and the compressor won't come back on. The trick is to start airing as soon as the tank pressure equals the tire pressure. If it won't fill, then you will have to fan down (via the brake pedal) to re engage the compressor. It's much easier with two people!
