wa8yxm
May 16, 2017Explorer III
It Depends a lot on how much of the mirror hit the ground.
If it is a remote power adjust.. Did the adjustment "Trolly" stick around? IF so you can attach the wires and snap it in place
If not then you first install the trolly.. THen attach the wires and snap it in place
You can also remove the glass from the frame (how is fairly easy though they do put a dollup of glue on one corner) put the entire frame together, then attach the wires as you put the glass back.
Doing this myself this week.
