Ralph_Cramden
Sep 12, 2017Explorer II
valhalla360 wrote:Ralph Cramden wrote:
What freezes is if there is moisture in the tank to begin with. I 2nd the bulk bottle recommendation. When it's cold you will not get as much out of the tank just from the pressure loss. When it gets down around 20 degrees or so, you'll only get about 60% to 70% out of a tank.
No, you will be able to use the full amount. The difference is at very low temperatures, the pressure created by the boiling propane may be too low to make it thru the regulator and/or it will make it thru at a slower rate.
Isn't too low of a pressure to make it through the regulator exactly the same as not being able to get all the propane from the tank? If its not going through the regulator it's certainly not coming out of the tank? If it is....where is it going?
