valhalla360
Sep 12, 2017Navigator
Ralph Cramden wrote:
Isn't too low of a pressure to make it through the regulator exactly the same as not being able to get all the propane from the tank? If its not going through the regulator it's certainly not coming out of the tank? If it is....where is it going?
If it's too low to get any thru the regulator, you aren't getting any out of the tank. An earlier post suggested you would get a percentage out of the tank.
If there is enough pressure to get thru the regulator, you will get all the propane out.
If there is not enough pressure you will none out.
But more importantly, if it's that cold that propane freezes, your furnace will struggle to keep the interior at 45-50F (even if you somehow get the propane to flow), so it's a good idea to head south.
