pianotuna
Sep 14, 2017Nomad III
Freezing can occur in the pressure regulator. Lack of sufficient vaporization can happen a few degrees above the boiling point. Running the furnace takes lots of vapor. Hence the need to raise the temperature of the tank.
I a magnetic block heater I can use. It does double duty as I can use it on my generator too.
Magnetic block heater 200 watts
