GPWayne
Apr 06, 2016Explorer
After reading all the posts I did see one error. When using a compressor to blow out the water lines, set the pressure at under 40 PSI, with the line capped. Then hook up to the water inlet
That way, if you close all the valves when the compressor is hooked up to your inlet you will not blow your plumbing. (The guy next door blew five fittings loose enough to leak. What a mess. We spent weeks finding the leaks...The hard to get to fittings were not as tight as the easy locations.)
Remember to blow out the ice maker fill line. I use power jumpers to open the electric valve.
38,782 PostsLatest Activity: Sep 10, 2026
